Topobase
Topobase
Valued Contributor
0 Kudos
Post 1 of 4
Installing Topobase System User (2010)
692 Views, 3 Replies
03-10-2010 07:18 PM
When attempting to install the Topobase System User I encounter a problem when logging into Oracle 11g:
" The User has insufficient privileges. Please login as Oracle user with DBA rights".
Screen captures are in the attached document.
Any suggestions would be greatly appreciated,
Brek
0 Kudos
Post 2 of 4
Re: Installing Topobase System User (2010)
03-11-2010 01:18 AM in reply to: spatialnetbrek
Try to use SYSTEM oracle user
Valued Contributor
0 Kudos
Post 3 of 4
03-11-2010 04:58 AM in reply to: spatialnetbrek
Thank you for your reply,
I have also tried SYSTEM with the same results. I connect thru SQL Developer with no problem.
Brek
Valued Contributor
0 Kudos
Post 4 of 4
03-11-2010 05:04 AM in reply to: spatialnetbrek
Have solved this issue:
SYS without the "AS SYSDBA" qualifier worked.
Post to the Community
New Post
