Topobase (Read Only)
Welcome to Autodesk’s Topobase Forums. Share your knowledge, ask questions, and explore popular Topobase topics.
Exporting SDF into Topobase
6 REPLIES 6
842 Views, 6 Replies
l am accessing Topobase for my company,
l have problem exporting SDF into Oracle
6 REPLIES 6
KernBlackburn
Can you provide a few more details about your situation? What kind of problem are you seeing? Are you getting an error message? Is the message from Oracle? What is the message number?
Kern
Hello Kern,
Thank you for the prompt response, I have issues linking my spatial data with Topobase. Also when I tried to digitise on the data in Map it gives an error about different coordinate, going back to the Administrator it will not allow me to edit the document spatial unit.
Is it possible to import SDF data into Topobase Client.
Many thanks,
Medoline
KernBlackburn
Yes it is possible to import SDF data into the Topobase Client. You can set up a data connection to an SDF file through the display manager.
Hi Kern,
l have displayed the SDF using Display Manager, cheers
Is it possible to insert the different features from the SDF into the data model?
The features have already been created using AutoCAD and Map 3D
Thank you.
KernBlackburn
Yes you can with provisions.
The feature classes should already exist in the Topobase workspace you are connected to and the coordinate systems are identical between the geometries coming in from the SDF file an the Topobase document.
Highlight the geometries in the drawing. Right-Click the feature class from the Topobase Explorer and "Create New Feature From Geometry"
K
Dear Kern,
It worked perfectly, thank you so much for your help Kern.
