The Community Room
The Community Room is a space to have conversations about anything you’d like to discuss with your fellow Engineers, Architects, Designers and basically all community members in here.
What program did I use? Calculate scale
4 REPLIES 4
440 Views, 4 Replies
Morning all,
At my last place of employment, I used a program where I could convert PDFs to a certain format, and then open that format up in an Autodesk application, find a measurement on the drawing and re-measure (which would always be wrong) but allowed me to set the scale from that dimension.
This was 7 years ago now and I can't for the life of me remember?
Does something like Design Review have a "Calculate scale" function?
4 REPLIES 4
Mistress0fTheDorkness
At this point, I use a PDF underlay to bring the file into autocad, then I use the scale by reference on a known point on the plan (if it's dimensioned, or a standard door size, etc) to get the pdf up to 1:1 scale and measure that.
Melanie Stone
Facilities Data Management
IWMS / CAFM / CMMS / AutoCAD / Archibus / Tririga / Planon / MRI Manhattan CenterStone / Revit / data normalization, data mapping, reporting and process documentation
mistressofthedorkness.blogspot.com/
pendean
There are dozens of PDF to DWG conversion programs for purchase, help yourself: try before you buy though and don't forget the main limitation: garbage in, garbage out (quality of the PDF is key, vector over raster is ideal).
in reply to: pendean
Thanks for your help so far!
I don't want to begin converting drawings as that ends up being more than I
actually require. All I'm after is a program that I can open PDFs, identify
a dimension on the drawing (say joinery unit at 3500mm long), measure the
dimension with a particular app and input what it *should be* (in this
example, 3500) and it resizes the drawing to suit allowing me to take off
other dimensions that *aren't* already identified on the PDF.
Does that make sense? I'm sure I used an Autodesk application years ago
that done this.
— Anthony
As I said, I've never used a program for this, but, it can easily be done within AutoCAD 2010 or higher, using the steps I outlined above.
Melanie Stone
