"IF WE TOOK THE BONES OUT, IT WOULDN'T BE CRUNCHY WOULD IT!?!?!"
"When I was sixteen years old, I thought my father was an idiot. By the time I turned twenty-one I was surprised how much he had learned in those five short years."
- Mark Twain
Twain had great quotes. I think he also said, "You'll never grow old if you continue to learn, continue to try new things and never mind being contradicted."
John Mayo
@Anonymous wrote:Twain had great quotes. I think he also said, "You'll never grow old if you continue to learn, continue to try new things and never mind being contradicted."
Which explains why my father has taken up learning to play the bodhran ... which he plays while reciting poetry or other things he's memorized.
Indeed. My Grandpa started learning AutoCAD right before he retired (in 1989), then took up home computers at that point. After he'd had enough of traveling, he took up a little graphic design on the pc, then bowling (which he'd never done before). Now, of course, he smokes us all in bowling on a regular basis. And, in his 80's, still lives on his own and gets around just fine. Good man. (he's picked up a few other hobbies over the years, but, those are the ones he stuck with.)
"I am your father! I brought you into this world, and I'll take you out!" - Cosby
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Mark Green
Working on Civil 3D in Canada
We've all heard, "If a job is worth doing, it's worth doing right."
The Government version is, "If a jog ISN'T worth doing, it ISN'T worth doing right."
@Anonymous wrote:"Hey, dId everything just taste purple for a second?"
Classic! Fry right?
"How often does the train go by?"
"So often you wont even notice it."
Winston Churchill
Your Name
"That looks perfect from my living room window."
"Well aren't you just SPECIAL!".... "ED!"
"This is not war, this is pest control!"
Chris Benner
Your Name
