The Break Room (Non-Technical Discussions)
Non-technical discussions will be held here to give community members a chance to connect and get to know one another.
Visitor
rigxGrip52
Message 1 of 7 (473 Views)
looking for advice
473 Views, 6 Replies
09-10-2013 06:03 PM
i don't own auto cad i am pencil and paper man but interested.  i am going to attempt to build a large sculpture of balerina. Because of the height it is gonna be built laying down . I am looking to be able to make drawing to plot my points in space. Example, like where the hand would be in relation to elbow. Am i heading in right direction or should i stick with the plumb bob because this is out of my league ?
*Expert Elite*
Charles_Shade
Message 2 of 7 (466 Views)
Re: looking for advice
09-10-2013 06:58 PM in reply to: rigxGrip52
How many years do you have in plumb bob experience? Works for you and is pretty accurate?
The 3D program is pretty expensive to do what you describe and you would likely spend a year (two?) getting proficient. Assuming that you used the program regularly.
And how do you propose to transfer the drawing to the model?
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
*Expert Elite*
dgorsman
Message 3 of 7 (436 Views)
09-11-2013 09:52 AM in reply to: Charles_Shade
Organic modeling is problematic with software created for technical design.  The difference being in art its about "that looks right" (appearance) whereas with engineering its about "that IS right" (numbers).  Not to say that it can't be done, CAD can be used to generate rough outlines, estimate materials, weight, etc.  3D visualization software is probably a better choice for this type of work, but as noted they are highly technical programs that require a lot of training and experience to produce acceptable work.
If you are going to fly by the seat of your pants, expect friction burns.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
Visitor
rigxGrip52
Message 4 of 7 (416 Views)
09-11-2013 04:41 PM in reply to: dgorsman
Thank you very much for your reply ,your simple explanation made me much more aware that buying the software is the easiest part, its mastering the art of making it do what you want it to do is the hard part. Using a string , plumb bob and some simple lasers is what i know and i just learned some facts about auto cad. Thank You
Visitor
rigxGrip52
Message 5 of 7 (412 Views)
09-11-2013 04:54 PM in reply to: Charles_Shade
Thank you for your reply you made me aware what auto cad is about . I was thinking turn it on and start going , now i am going to polish up the plumb bob.The part i missed was auto cad is an art in itself . Thank you very much.
*Expert Elite*
Cadmanto
Message 6 of 7 (320 Views)
09-27-2013 11:13 AM in reply to: rigxGrip52
If you don't have any experience using CAD software I can see you could get pretty aggrivated and frustrated in trying to get the software to give you what you want along with the added headaches of learning it.  There is nothing wrong with pushing a pencil.  If it works for you and you are comfortable in using it, then use it.  If this is a leasure project or a hobby at home, I wouldn't waste my time learning software to do it.
Are you feeling pressures to do this in CAD?
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
Visitor
rigxGrip52
Message 7 of 7 (312 Views)
09-27-2013 12:26 PM in reply to: Cadmanto
art project for burnning man2014
Need installation help?
