The Community Room
The Community Room is a space to have conversations about anything you’d like to discuss with your fellow Engineers, Architects, Designers and basically all community members in here.
For metric dimensioning of holes what would N°8 M12X1D mean?
7 REPLIES 7
Message 1 of 8
998 Views, 7 Replies
For metric dimensioning of holes what would N°8 M12X1D mean? Sorry that I am not really sure where this would go, a guide to metric hole dimensioning standards would be great.
7 REPLIES 7
Message 2 of 8
Charles_Shade
What's your AutoCAD platform?
Message 3 of 8
troma
I believe an M12 thread is a bolt with an outside diameter of 12mm.  So the question logically arises: are you drilling a hole to tap a thread for this bolt, or a hole that it can pass through without hitting the edges?
My gut feeling is that you will get the best answer if you ask the person who gave you this spec.
Do any of these help:
http://www.efunda.com/DesignStandards/screws/screwm_coarse.cfm
http://www.efunda.com/DesignStandards/screws/screwm_fine.cfm
http://www.metrication.com/engineering/threads.htm
http://en.wikipedia.org/wiki/Metric_thread
I think the 1D part refers to the hole being the depth of 1 diameter.
http://www.engineeringsupplies.co.uk/metric-fine-helicoil-insert-pack-1000-p-7453.html
Mark Green
Working on Civil 3D in Canada
Message 4 of 8
Charles_Shade
in reply to: troma
I wonder if the N 8 is the grade of the bolt/screw?
Your answer is one of the thouroughly researched and complete ones that needs a Kudos.
Message 5 of 8
troma
in reply to: Charles_Shade
Thanks Charles, but with Google to hand it doesn't take much to find a few interesting sites!
By the way, on the subject of Kudos, your signature line is a little incongruous on this forum! Smiley LOL
(mine too, I guess)
Mark Green
Message 6 of 8
Charles_Shade
in reply to: troma
Should we ask for an alternative signature for non-Kudos Forums?
You are absolutely right about Google making things easy but you took the time to look and find those sites when the OP did not do so. They looked for the easy answer; hopefully finding it here, and found out that they needed to do some research for themselves. A good local hardware store may have been an answer for them too.
Message 7 of 8
Rory_M
It is a little confusing, and usually you would say M10 x 15 (as an example for a hole that is a 10mm metric thread by 15mm deep)
The x1D bit is odd, maybe it's a typo or dodgy old drawing that's hard to read
I don't suppose it actually says No8 M12x10 does it? If it did it would mean:
No8 is the quantity - 8 off holes
M12 is the thread - M12 thread (standard is 12mm diameter by 1.75mm pitch)
x10 Would usually be depth after the thread size, so 10mm deep
Hope this is useful.
Rory
Message 8 of 8
troma
in reply to: Rory_M
Rory, the link I posted earlier show the D referes to the diameter.
So the depth of the hole is equal to the diameter.
Mark Green
