The Community Room
The Community Room is a space to have conversations about anything you’d like to discuss with your fellow Engineers, Architects, Designers and basically all community members in here.
First Forum Post. Can you find yours?
36 REPLIES 36
Message 1 of 37
Charles_Shade
2286 Views, 36 Replies
36 REPLIES 36
Message 2 of 37
CoreyDaun
in reply to: Charles_Shade
Revit MEP forum » Referencing the "Total Connected" panelboard parameter
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Message 3 of 37
troma
I've only ever had one log-in.  (I seem to be unusual in that.)  So it's quite easy to find:
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Uninstall-2008-kills-2006/m-p/2260521#M76963
Now, I'd be interested if anyone's first post was to answer a question, rather than ask one.
Mark Green
Working on Civil 3D in Canada
Message 4 of 37
CoreyDaun
Charles, you never responded to Dean in your first post! Did his suggestion work? Smiley Tongue
Troma, I started addressing questions with my second post. Does that count for anything?
Message 5 of 37
hwalker
in reply to: troma
This looks like my very first post. 2 minutes after I logged in
http://forums.autodesk.com/t5/AutoCAD-LT/Batch-plot/m-p/1033486#M42493
Howard Walker
Left Handed and Proud
Message 6 of 37
troma
in reply to: hwalker
So you were just a helper from the start?
My second post was an update on the same thread as my first, but my third post was trying to help someone else.
Mark Green
Message 7 of 37
Charles_Shade
Howard - I used that batch plot utility for years.
My registration shows 5-24-2003 but the ifrst post is 5-20-2002. So when did I start?
First answer given: 10-2-2002 Still relevant today for the older Version users.
http://forums.autodesk.com/t5/AutoCAD-LT/Saving-AutoCAD-window-setup/m-p/371167#M4443
Message 8 of 37
hwalker
Yeah I was proud of that. I even got a little bit c.ocky with it and put in a bit so it would put the messages in other languages
Howard Walker
Message 9 of 37
AcadAdamLT
http://forums.autodesk.com/t5/Dynamic-Blocks/Dynamic-block-issue/td-p/2852816
This was mine, over 2 years now ^^
Signature, sincerely... //Adam
AutoCad LT 2016
Give Kudos where credit is due, Mark "accepted as solution" if the post solved your question.
Message 10 of 37
CADiva
Layer Manger Buttons ... wow, that was a ways back (for me, at least).
Message 11 of 37
troma
in reply to: CADiva
Link is broken—for me at least.
Mark Green
Message 13 of 37
pendean
I think I responded to posts first instead of starting a post I think.
Now which profile name was that... 😞
Message 14 of 37
What a fun topic!
Hmm, I can't believe I didn't start posting here until I was 25... could've sworn I started younger, I guess I'm just thinking of my AUGI posts.
First post was a test:
http://forums.autodesk.com/t5/Test/testing-1-2/m-p/1561482
Oh, my first real post was tutting someone's bad behavior... sounds like me! lol.
http://forums.autodesk.com/t5/CAD-Managers/How-many-peeps-per-Cad-Manager/m-p/1559164#M51149
lol, wow, this is fun. Checked out some other older posts of mine, looks like right about the time I started becoming friends with some of the folks in the CAD Manglers forum... those peeps are awesome.
Melanie Stone
Facilities Data Management
IWMS / CAFM / CMMS / AutoCAD / Archibus / Tririga / Planon / MRI Manhattan CenterStone / Revit / data normalization, data mapping, reporting and process documentation
mistressofthedorkness.blogspot.com/
Message 15 of 37
I don't know how my email log-in got disconnected during one of Autodesk's log-in merge things, but, I do know one of my profiles is because I was posting via NNTP. That was the bulk of my posts, and I wish I could've kept those associated with my profile at that time. C'est la vie.
Melanie Stone
Message 16 of 37
CADiva
in reply to: troma
This should work: http://forums.autodesk.com/t5/Autodesk-Architectural-Desktop/Layer-manager-missing-buttons/m-p/11025...
(I would've edited my other post, but I can't see a way to do that ... am I missing something?)
Message 17 of 37
AHA! Nevermind, I was 23! (stoopid multiple profiles)
http://forums.autodesk.com/t5/AutoCAD-Map-3D/MAP-for-Facilities-Management/m-p/974806
I almost forgot about my MAP phase. Heh.
Melanie Stone
Message 18 of 37
The options flyout on the upper right of your post should have an 'Edit Reply' at the top.
Melanie Stone
Message 19 of 37
That's what I thought ... but I'm not that special apparently.
Message 20 of 37
troma
in reply to: CADiva
There's a time limit, and also I think if someone replies it is locked for editing.
Mark Green
