The Community Room
The Community Room is a space to have conversations about anything you’d like to discuss with your fellow Engineers, Architects, Designers and basically all community members in here.
Duplicate forum?
4 REPLIES 4
bgingerich
611 Views, 4 Replies
Duplicate forum?
Came across this site, www.chemical-forum.com , that has duplicate postings as on here.  Anybody know anything about it?
Example: http://www.chemical-forum.com/thread-128577-1-1.html
and         http://forums.autodesk.com/t5/AutoCAD-2010-2011-2012-DWG/Where-is-Autodesk-Exchange/m-p/3173320#M627...
Hosted by GoDaddy.com out of Phoenix, AZ.
I know, I know, I'm really nosey.
Brandon Gingerich
4 REPLIES 4
Charles_Shade
in reply to: bgingerich
Well isn't that fun!
Lots of Forum Veteran's in there. Quite a few alter egos running around it would seem.
You seem to be 8mjsrl1
How did you come across this anyway? Google?
AcadAdamLT
in reply to: Charles_Shade
Chemical forums.. trippy..
Signature, sincerely... //Adam
AutoCad LT 2016
Give Kudos where credit is due, Mark "accepted as solution" if the post solved your question.
bgingerich
Yeah, Google it was.  The funny thing is, if you try to see a listing of the posts that each member/alter ego has, there is none.  At least I couldn't find a way do it without signing up (which I will not do)!
Another nose around shows that there are threads there from www.reefcentral.com ?  And someone else is ticked about it too!  http://www.chemical-forum.com/thread-1100983-1-1.html
Brandon Gingerich
rkmcswain
I've seen many of those over the years.
Just assumed these sites were mirroring the data while hoping for ad-clicks.
