Stingray crash at startup
Message 1 of 23
Hello
I just install Stingray, and it crash at startup.
Here is the log
18:01:17 [Info] - Running build dc0c2c87edbff1f8fa2793096d4479a54db4fea6
18:01:17 [Debug] - 19/08/2015 18:01:17 [Info] Server started at ws://127.0.0.1:12010
18:01:17 [Debug] - 19/08/2015 18:01:17 [Info] Server started at ws://127.0.0.1:12011
18:01:17 [Debug] - Loading services took 69 ms
18:01:17 [Debug] - Application registration took 192 ms
18:01:18 [Debug] - System.Net.HttpListenerException (0x80004005): Accès refusé
   à System.Net.HttpListener.AddAllPrefixes()
   à System.Net.HttpListener.Start()
18:01:19 [Debug] - System.InvalidOperationException: Unable to configure namespace reservation
   à Nancy.Hosting.Self.NancyHost.StartListener()
18:01:29 [Error] - System.InvalidOperationException: Unable to configure namespace reservation
   à Nancy.Hosting.Self.NancyHost.Start()
   à Stingray.StingrayEditorBackend.Program.Main(String[] args)
I have autorized Stingray and Game launcher in Firewall but it is not the solution....
Can you help ? Thanks
Replies (22)
Message 2 of 23
Hi there,
I had similar issue. Starting Stingray as admin helped me to launch the editor. Have you tried this?
Message 3 of 23
I will try, thanks
Message 4 of 23
You welcome!
Please post the result, maybe we can spare someone google for solution 🙂
Message 5 of 23
andrew.grant
This looks like a knonw issue which occurs when using a non-english version of Windows. The workaround is to run as admin.
Hope that works.
Thank you!
Message 6 of 23
Hey,
Had the same problem, running as administrator worked for me.
Message 7 of 23
andrew.grant
HaroldRINCK9177,
Could you share with me your system details? We'd like to get this resolved for the patch release.
Could you provide:
1. Antivirus software used
2. Firewall settings
3. Windows version and language
4. Do you have UAC on or off?
Thank you!
Message 8 of 23
mmmfrrr, I'm ashamed...
yes, running Stingray as administrator do the job. 🙂
for the questions :
1- Microsoft security essential
2- Firewall on, but allow Stingray and Game launcher don't resolve problem
3- Win 7 pro SP1 french
4- uac off
Cheers
Message 9 of 23
Here are responses.
1- MBullguard
2- Firewall on, but I have switched it off too and had the same problem.
3- Win 8.1 French
4- uac was on but I have now turned it off.
Cheers
Neil
Message 10 of 23
i have black screen on stingray and gamelauncher what should i do ?
Message 11 of 23
andrew.grant
Thanks for all the details!
Mcanbaspinar, is this whenever you start the applications or did you change your display configuration - like enable/disable multi monitor?
Message 12 of 23
it offers me close windows aero. i click yes. also i tried open without closing windows aero. nothing changed.. still blackscreen. but my mouse changes  when i try to click something inside black screen. i can see some paths c://programfiles... or something like that.
Message 13 of 23
gebert
Same Problem:
15:06:17 [Info] - Running build dc0c2c87edbff1f8fa2793096d4479a54db4fea6
15:06:17 [Debug] - 20.08.2015 15:06:17 [Info] Server started at ws://127.0.0.1:12010
15:06:17 [Debug] - 20.08.2015 15:06:17 [Info] Server started at ws://127.0.0.1:12011
15:06:17 [Debug] - Loading services took 184 ms
15:06:17 [Debug] - Application registration took 1087 ms
15:06:18 [Debug] - System.Net.HttpListenerException (0x80004005): Zugriff verweigert
bei System.Net.HttpListener.AddAllPrefixes()
bei System.Net.HttpListener.Start()
15:06:27 [Debug] - System.InvalidOperationException: Unable to configure namespace reservation
bei Nancy.Hosting.Self.NancyHost.StartListener()
15:06:48 [Error] - System.InvalidOperationException: Unable to configure namespace reservation
bei Nancy.Hosting.Self.NancyHost.Start()
bei Stingray.StingrayEditorBackend.Program.Main(String[] args)
OS:Windows 10
Two Monitors
Message 14 of 23
Hallo,
ich hatte auch folgenden Fehler in der Logdatei:
20:02:03 [Info] - Running build dc0c2c87edbff1f8fa2793096d4479a54db4fea6
20:02:03 [Debug] - 20.08.2015 20:02:03 [Info] Server started at ws://127.0.0.1:12010
20:02:03 [Debug] - 20.08.2015 20:02:03 [Info] Server started at ws://127.0.0.1:12011
20:02:03 [Debug] - Loading services took 108 ms
20:02:03 [Debug] - Application registration took 353 ms
20:02:04 [Debug] - System.Net.HttpListenerException (0x80004005): Zugriff verweigert
20:02:07 [Debug] - System.InvalidOperationException: Unable to configure namespace reservation
20:02:19 [Error] - System.InvalidOperationException: Unable to configure namespace reservation
bei Stingray.StingrayEditorBackend.Program.Main(String[] args)"
Nachdem ich das Programm als Admin ausgeführt habe hat es funktioniert....
Ich nutze Windows 10 und habe einen i5 er mit 8GB RAM
Ich hoffe ich konnte helfen.
Schöne Grüße
Matthias
Message 15 of 23
andrew.grant
Mcanbaspinar, have you tried running as administrator?
Do you have any errors in your error log? Can you send the log?
Message 16 of 23
andrew.grant
If you are experiencing this crash on startup, and running as admin works, please try running the following from commandline:
netsh http add urlacl url=http://*:55503/ sddl=D:(A;;GA;;;WD)
Then try running normally - not as admin and please post results.
Thank you.
Message 17 of 23
bthompson
I am having this same issue with the English version of Stingray, and the command above did not fix it.
In my case the user of the workstation is NOT an administrator, none of our users are. Do you have to be an administrator to run Stingray? Stingray runs fine when an administrator logs into the same workstation.
Message 18 of 23
matthew.carpenter
Hi Harold,
Can you open a command prompt as administrator and run the following command:
netsh http add urlacl url=http://+:55503/ sddl=D:(A;;GA;;;WD)
Let me know if this solution worked for you.
Message 19 of 23
bthompson
This second version of the command worked for me. Plus instead of star.
Message 20 of 23
M_LUDWIG
Admin option solved the issue
