Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Dual screen layout
5 REPLIES 5
Leendert68
8480 Views, 5 Replies
Dual screen layout
One of the first things I noticed after installing the demo is that there doesn't seem to be an easy way to get a full dual screen/monitor setup in Maya, while this was included in Softimage "out of the box". I found a third-party script that addresses this problem and it might well just be that I am overlooking something, but a clear way to setup a dual screen layout would be a definite plus in my book.
5 REPLIES 5
sonictk
in reply to: Leendert68
Hi Leendert: You can tear off panels and windows, and save those window layouts as well. (Window > Saved layouts) Viewports can also be placed on secondary monitors and those locations saved in this manner as well. Is there something that you are specifically looking for that cannot be handled in this manner?
Leendert68
in reply to: sonictk
Yes, I did notice that, but I find that a bit messy, considering the simplicity and elegance of a fixed, tabbed solution Softimage offers.
sonictk
Actually XSI has crappy dual monitor support for me (since I never have two monitors of the same size 😛 and XSI refuses to launch fullsize on non-primary monitors) but I run ultramon scripts to handle this.
You can try setting your windowPrefs.mel to launch Maya with a custom window resolution, if you want to make use of all your screen estate. But yea, I don't recall any such way to do dual-screen OOTB.
Leendert68
True, I always use two monitors of exactly the same size. And with such a setup I never had any problems...
This is the workaround  for Maya I found so far: http://tinyurl.com/qbce7h5
AlanEddie
Hi there, it doesn't seem to remember say Outliner (When I save a layout.)when it's placed on the other monitor, just seems to remember the views, where the 4 view is?
So I can't have hypergraph etc on my other monitor ?
Thanks.
Alan Eddie
___________________
3d Animation/f/x /Design / Scripting
alaneddie.com
