Area :: Header
3ds Max 2015 Extension 1 is here
With new tools to power your pipeline
Discussion Groups
Softimage General
burg_1
MD5 Exporter
49 Views, 3 Replies
09-27-2011 07:12 AM
Hey All,
Does anyone know of a Softimage MD5 exporter?
I can't seem to track one down.
Burg
Please use plain text.
New Member
Andre Bastien
Re: MD5 Exporter
09-28-2011 01:51 PM in reply to: burg_1
What to you exactly need?
If it's for already saved files, here's a python code which will give you the md5 of the file:
import hashlib
file = open("your_file_path", "rb") # Replace 'your_file_path' by the path of your file.
to_hash = file.read()
file.close()
m = hashlib.md5() # You can use other format instead of md5 (sha1, sha224, sha256, sha384 and sha512)
m.update(to_hash)
md5 = m.hexdigest()
print md5
If you want the md5 of a softimage object which is still not saved (only in memory), I can't help you on that.
burg_1
Re: MD5 Exporter
09-29-2011 03:23 AM in reply to: burg_1
Andre,
Thanks for your reply. However I believe I failed to remember that MD5 is also the name of cryptographic Hash function as well as a Mesh format!
See here: http://www.modwiki.net/wiki/MD5MESH_(file_format). I guess I should've put MD5Mesh Exporter. Sorry for being unclear.
So does anyone know about a MD5Mesh and MD5Anim Exporter?
Bry
burg_1
Re: MD5 Exporter
10-05-2011 01:57 PM in reply to: burg_1
Anyone help me with this?
Cheers
Burg
