Smoke Forum
Welcome to Autodesk’s Smoke Forums. Share your knowledge, ask questions, and explore popular Smoke topics.
Smoke crashes when open workspace
2 REPLIES 2
809 Views, 2 Replies
Hello Everyone !
I a problem in two machines with the same OS and Smoke
Elcapitan 10.11.3
Smoke 2016
When open smoke and select the project the smoke crashes in 'Load Workspace', all projects have the same error
The console
11/5/16 2:12:10.702 PM LMU[35426]: 35426 DAEMONIZE: session new session leader
11/5/16 2:12:10.703 PM LMU[35426]: 35426 DAEMONIZE: tty disconnect parent exiting
11/5/16 2:12:10.703 PM LMU[35427]: 35427 DAEMONIZE: tty disconnect child
11/5/16 2:12:10.703 PM LMU[35427]: 35427 DAEMONIZE: closing file descriptors
11/5/16 2:12:10.703 PM LMU[35427]: 35427 Execing /Applications/Autodesk/Adlm/R11/LMU.app/Contents/MacOS/lmuopen
11/5/16 2:12:10.703 PM LMU[35427]: 35427 with argument: lmuopen
11/5/16 2:12:10.703 PM LMU[35427]: 35427 with argument: /Applications/Autodesk/Adlm/R11/LMU.app/Contents/MacOS/LMU
11/5/16 2:12:10.710 PM lmuopen[35427]: Launching: /Applications/Autodesk/Adlm/R11/LMU.app/Contents/MacOS/LMU
11/5/16 2:12:10.748 PM LMU[35428]: WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.3 instead of 10.11.3. This is not a bug in Gestalt -- it is a documented limitation. Use NSProcessInfo's operatingSystemVersion property to get correct system version number.
Call location:
11/5/16 2:12:10.749 PM LMU[35428]: 0 CarbonCore 0x00007fff83fa8c9b ___Gestalt_SystemVersion_block_invoke + 113
11/5/16 2:12:10.749 PM LMU[35428]: 1 libdispatch.dylib 0x00007fff8996133f _dispatch_client_callout + 8
11/5/16 2:12:10.749 PM LMU[35428]: 2 libdispatch.dylib 0x00007fff89961237 dispatch_once_f + 67
11/5/16 2:12:10.749 PM LMU[35428]: 3 CarbonCore 0x00007fff83f34b47 _Gestalt_SystemVersion + 987
11/5/16 2:12:10.749 PM LMU[35428]: 4 CarbonCore 0x00007fff83f33ddb Gestalt + 139
11/5/16 2:12:10.749 PM LMU[35428]: 5 libQtCoreAdlm.4.dylib 0x000000010722c616 _Z41__static_initialization_and_destruction_0ii + 70
11/5/16 2:12:10.749 PM LMU[35428]: 6 ??? 0x00007fff6709af8b 0x0 + 140734922076043
11/5/16 2:12:10.000 PM kernel[0]: process smoke[35369] caught causing excessive wakeups. Observed wakeups rate (per sec): 25029; Maximum permitted wakeups rate (per sec): 150; Observation period: 300 seconds; Task lifetime number of wakeups: 45083
11/5/16 2:12:10.761 PM com.apple.xpc.launchd[1]: (com.apple.ReportCrash.Root[35429]) Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.ReportCrash.DirectoryService
11/5/16 2:12:10.776 PM launchservicesd[86]: SecTaskLoadEntitlements failed error=22
11/5/16 2:12:10.780 PM launchservicesd[86]: SecTaskLoadEntitlements failed error=22
11/5/16 2:12:10.804 PM launchservicesd[86]: SecTaskLoadEntitlements failed error=22
11/5/16 2:12:11.101 PM appleeventsd[54]: SecTaskLoadEntitlements failed error=22
11/5/16 2:12:13.007 PM spindump[709]: No microstackshots found
11/5/16 2:12:26.021 PM WindowServer[198]: CoreAnimation: serialization error from context 30db3f2
11/5/16 2:12:28.492 PM sandboxd[141]: ([406]) fontd(406) deny file-issue-extension /usr/discreet/font/Type1/Discreet.pfa
11/5/16 2:12:28.510 PM sandboxd[141]: ([406]) fontd(406) deny file-issue-extension /usr/discreet/font/Type1/Discreet-Italic.pfa
11/5/16 2:12:28.528 PM sandboxd[141]: ([406]) fontd(406) deny file-issue-extension /usr/discreet/font/Type1/Discreet-Bold.pfa
11/5/16 2:12:28.546 PM sandboxd[141]: ([406]) fontd(406) deny file-issue-extension /usr/discreet/font/Type1/Discreet-BoldItalic.pfa
11/5/16 2:12:29.664 PM appleeventsd[54]: SecTaskLoadEntitlements failed error=22
11/5/16 2:12:29.678 PM launchservicesd[86]: SecTaskLoadEntitlements failed error=22
11/5/16 2:12:29.780 PM identityservicesd[403]: <IMMacNotificationCenterManager: 0x7f906c80f120>: notification observer: com.apple.iChat notification: __CFNotification 0x7f906ac5e6b0 {name = _NSDoNotDisturbEnabledNotification}
11/5/16 2:12:29.794 PM identityservicesd[403]: <IMMacNotificationCenterManager: 0x7f906c80f120>: NC Disabled: NO
11/5/16 2:12:29.798 PM identityservicesd[403]: <IMMacNotificationCenterManager: 0x7f906c80f120>: DND Enabled: YES
11/5/16 2:12:29.798 PM identityservicesd[403]: <IMMacNotificationCenterManager: 0x7f906c80f120>: Updating enabled: NO (Topics: (
11/5/16 2:12:30.687 PM WindowServer[198]: disable_update_timeout: UI updates were forcibly disabled by application "Autodesk Smoke" for over 1.00 seconds. Server has re-enabled them.
11/5/16 2:12:33.850 PM WindowServer[198]: common_reenable_update: UI updates were finally reenabled by application "Autodesk Smoke" after 4.16 seconds [0.24fps] (server forcibly re-enabled them after 1.00 seconds [1.00fps])
11/5/16 2:12:33.968 PM launchservicesd[86]: SecTaskLoadEntitlements failed error=22
11/5/16 2:12:34.066 PM coreaudiod[228]: SecTaskLoadEntitlements failed error=22
11/5/16 2:12:51.914 PM smoke[35369]: dynamic_cast error 2: One or more of the following type_info's has hidden visibility. They should all have public visibility. 15CoTokenProducer, ZNK18PrjSavedBatchEntry22populateTokenProducersERSt6vectorI11CoSharedPtrI15CoTokenProducerESaIS3_EEE22BatchSavedTimeProducer, 11WeakSubject.
11/5/16 2:12:51.919 PM smoke[35369]: dynamic_cast error 2: One or more of the following type_info's has hidden visibility. They should all have public visibility. 15CoTokenProducer, 19CoTimeTokenProducer, 11WeakSubject.
11/5/16 2:12:51.919 PM smoke[35369]: dynamic_cast error 2: One or more of the following type_info's has hidden visibility. They should all have public visibility. 15CoTokenProducer, 22CoNetworkTokenProducer, 11WeakSubject.
11/5/16 2:12:51.926 PM smoke[35369]: dynamic_cast error 2: One or more of the following type_info's has hidden visibility. They should all have public visibility. 15CoTokenProducer, 22CoNetworkTokenProducer, 11WeakSubject.
11/5/16 2:12:52.177 PM launchservicesd[86]: SecTaskLoadEntitlements failed error=22
11/5/16 2:12:52.182 PM launchservicesd[86]: SecTaskLoadEntitlements failed error=22
11/5/16 2:12:52.183 PM launchservicesd[86]: SecTaskLoadEntitlements failed error=22
11/5/16 2:12:52.347 PM identityservicesd[403]: <IMMacNotificationCenterManager: 0x7f906c80f120>: notification observer: com.apple.iChat notification: __CFNotification 0x7f906ad27cf0 {name = _NSDoNotDisturbDisabledNotification}
11/5/16 2:12:52.358 PM identityservicesd[403]: <IMMacNotificationCenterManager: 0x7f906c80f120>: NC Disabled: NO
11/5/16 2:12:52.361 PM identityservicesd[403]: <IMMacNotificationCenterManager: 0x7f906c80f120>: DND Enabled: NO
11/5/16 2:12:52.361 PM identityservicesd[403]: <IMMacNotificationCenterManager: 0x7f906c80f120>: Updating enabled: YES (Topics: (
11/5/16 2:12:52.792 PM com.apple.xpc.launchd[1]: (com.apple.CoreRAID[36148]) Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.CoreRAID
11/5/16 2:12:53.072 PM system_profiler[36153]: SPUSBDevice: IOServiceGetMatchingService did not return anything for location 0x00200000
11/5/16 2:12:53.072 PM system_profiler[36153]: SPUSBDevice: IOServiceGetMatchingService did not return anything for location 0x00300000
11/5/16 2:12:53.073 PM system_profiler[36153]: SPUSBDevice: IOServiceGetMatchingService did not return anything for location 0x00420000
11/5/16 2:12:53.073 PM system_profiler[36153]: SPUSBDevice: IOServiceGetMatchingService did not return anything for location 0x00400000
11/5/16 2:12:53.073 PM system_profiler[36153]: SPUSBDevice: IOServiceGetMatchingService did not return anything for location 0x00700000
11/5/16 2:12:54.159 PM appleeventsd[54]: SecTaskLoadEntitlements failed error=22
11/5/16 2:12:57.245 PM launchservicesd[86]: SecTaskLoadEntitlements failed error=22
11/5/16 2:12:57.246 PM launchservicesd[86]: SecTaskLoadEntitlements failed error=22
11/5/16 2:13:01.190 PM LMU[35426]: exiting and supressing hooks: 0
But when create a new media storage the smoke start correctly.
2 REPLIES 2
jaseo
Those issues would be related to a corrupt partition. We can rebuild the stone+wire database. Autodesk Support would normally do this, but since you only have basic support, you can follow these steps (with great care)
1. Open Service Monitor and STOP stone+wire.
2. open a terminal, and type the following commands.
cd /usr/discreet/sw/swdb
mv part0* /tmp
nb. part0 in the above refers to the partition to rebuild.
3. START stone+wire in the Service Monitor
4. Now you need to run a vic which will rebuild the database. This could take a while depending on the number of frames (anywhere between 5mins and 60mins)
/usr/discreet/io/bin/vic -a
this will run a vic on all partitions which is fine.
Once it completes, look in /usr/discreet/sw/swdb
make sure the  part0.db-lock is no longer there. Sometimes it takes a while after the initial vic completes.
You can keep running the vic command to see if the part0.db is still increasing.
(or look at the /usr/discreet/sw/log/sw_dbd.log to see if it still doing stuff)
Once it is finished, part0.db-lock will be removed and you should be able to get back in.
However, you may still have corrupt clips. You will need to either flush cache/recache, and flush renders/rerender in those cases. All new renders should now be fine.
I have seen this happen if the mac is hard powered down or after a big crash, as well as when vic has not been run for a while.
cheers
Jason
in reply to: jaseo
Hello Jason !!! Works Fine !! Many Thanks 😉
I moved all part0,1,2,3,4... because the media is configured on stonefs7, after i maked the vic -a and the db increased to 256mb.
Many thanks Bro !
