I would like to know if downloading the 2017 version of Autodesk Smoke, all the projects that I have created in 2016 version will be saved and I will be able access them whenever I want in this new version?
Thank you for the support
Alberto
Solved by jaseo. Go to Solution.
Hi Alberto,
You cannot open a project created in a previous version of Smoke without first converting it.
To open a project created in a previous version:
It can happen that you cannot convert a project; oftentimes it is because the project comes from a fairly old version of Smoke. In this case, use either of the following methods to open and access the contents of the project.
cheers,
