Active Member
AutoDebilitator
With new version, can't create a box with numerical inputs anymore.
179 Views, 5 Replies
03-16-2014 12:50 PM
With the latest version, I'm unable to create a 2nd box in a model by specifying numerical inputs.  Steps to reproduce:
1.  Create a box.
2.  Create a 2nd box, starting on one corner of the first box.  Don't use the mouse to draw the initial rectangle, just use the  mouse to select the firrst point, then use the numeric inputs.
3.  Type a length in, then a width.  Click return twice, which used to bring up the dialogue to enter the height.
Expected results:  Dialog comes up, and you can enter the height.
Actual results:  Get the error "Sketch geometry is over constrained."
The work-around is to draw the initial rectangle with this mouse, which is imprecise, but then a dialogue will come up allowing you to enter all 3 dimensions, which works.
Also, when entering the dims using step 3 above, it will always lose the first key input on the 2nd dim.  I.e., if I try to enter "3" return, then "14", I'll wind up with "3" and "4" instead.
AutoD
Please use plain text.
Employee
Cathy.Wang_Autodesk
Re: With new version, can't create a box with numerical inputs anymore.
03-17-2014 02:59 AM in reply to: AutoDebilitator
Thanks for posting about this problem
Unfortunately we were not able to reproduce the error "Sketch geometry is over constrained." here, is it possible to attach a video about this?
About the input problem you mentioned on the end, I will transfer it to Product designer to take a look it.
Now, you can try to enter the value without pause, it should be work well. If you want to enter other value, you don't need to remove the old value and enter the new value directly. I hope you like the design.
Cathy Wang
Software QA Engineer
Fusion 360 Quality Assurance Team
Active Member
AutoDebilitator
04-06-2014 10:37 AM in reply to: Cathy.Wang_Autodesk
I've attached a video reproducing this issue. The numerical inputs I'm
doing via keyboard for all dims. After entering the 1st two dims for the
second box, I hit "Enter" twice to have it move to inputting the 3rd dim,
and this is where the error happens.
Rob
AutoD
Helmi74
04-06-2014 11:14 PM in reply to: AutoDebilitator
think you forgot the video? can't see any.
Frank (@helmi / Twitter)
MacOSX 10.9 (iMac 2013)
Please support my ideas and comments to improve Fusion360. (link removed as it doesn't work anymore, see my ideas in the idea section)
Active Member
AutoDebilitator
04-15-2014 12:45 PM in reply to: Cathy.Wang_Autodesk
Here's a video reproducing this issue:
Or you can go to this URL:  https://vimeo.com/92069009
Rob
AutoD
Employee
Cathy.Wang_Autodesk
04-15-2014 07:06 PM in reply to: AutoDebilitator
Thanks a lot, Rob!
It's a perfect video. I get the problem clearly now. I will report the case into the internal issue tracking system and ask the development team to look into it.
There is a workaround. You can try to use click to replace Press Enter when set the second sketch point. There is no error popping up.
Cathy Wang
