I just started fusion 360 this morning, got a message that it had to be upgraded, and now I cannot find any of my projects. HELP!!!
Thanks!
Solved by sanjay_jayabal. Go to Solution.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
If you haven't read the September update - http://forums.autodesk.com/t5/design-differently/september-update-is-live/ba-p/5242253 - post yet, please take a few minutes to do so, I think you will find it helpful. Regarding your projects, you should see a Grid like icon in the top left corner, if you click it, it should expose the Data Panel. In the Data Panel, there should be a Projects drop down in the top left. Please let us know if you are not seeing this.
best regards,
Sanjay Jayabal
