In sketch mode the view obscured by a white band when clicking below a horizontal about 2/3 down from top of display area.
The top snapshot in posted jpg shows the fusion360 sketch before click while the bottom snapshot shows fusion360 sketch obscured by white band - occurs in all models.
Setting problem??? Tried turning on and off all posible view attributes.
Solved by peterschlem. Go to Solution.
Solved by innovatenate. Go to Solution.
I noticed that you are running the Windows OS. Any idea if the graphics driver is up to date on your machine?
To check on the install date:
If you find that the graphics driver is older than 6 months, it may help to update it.
If you disable the Environment Effects, does it help?
If you have an older Graphics Card, it may help to switch to DirectX 9 in the Preferences.
I hope these suggestions help. Please keep me updated on your progress.
