Not sure how to put things together in Fusion? Use joints! You'll see how to create joints and learn some tips along the way.
Patrick,
These videos you are posting are terrific for explaining the various commands and options- far better than the text reference. My concern is that they are not easy to find when buried in the forums.
How about having a link from the Command Reference section of the Learn tab to videos that would be appropriate for each command set- this for instance would be linked under the Assemble panel. This would represent a much better way to fully explain the commands, and would make the videos easy to find.
Ron
Hi Ron,
Thanks for the feedback. There will be a new help framework for the next release that will allow exactly that. The help will contain text references and videos with appropriate linking between. I will also be able to update on the fly so new videos will be posted to the help. Until then, posting to the forums is the best I can do.
And thanks to stevie.d for linking the video post in the Tips and Tricks post.
