Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Using fusion 360 for casts
2 REPLIES 2
fpessolano
215 Views, 2 Replies
Hi
I have been using fusion so far for models for our 3D printer. We are now considering using casts for resins and I was wondering is there are tools in fusion that facilitate the generation of casts from a gived design.
Francesco
2 REPLIES 2
deyop
in reply to: fpessolano
Not sure what kind of casts you are considering?  Plaster, Urethane or silicone?  One of the basic tools would be the Draft Analysis command that will display undercuts.  It will update dynamically so if you are direct modeling a Sculpt body the analysis will show when you are locking something.
Draft Analysis Video
Does that help?  Was there something else you had in mind?
fpessolano
in reply to: deyop
Hi
Thanks. I will check. I meant silicon casts.
Cheers
F.
