I'm working some imported parts that were apparently originally created in metric. If I use the measure tool I get readings in mm even though I've set prefs on inches, etc. Is there a way to convert the whole document to inches?
Solved by innovatenate. Go to Solution.
Have you tried editing the Units in the Browser?
Hi
I'm having a similier problem, I built in mm with the intention to build in inches. now everything is incredibly small lol. Is it possible to automatically scale everything up to inches
