Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Unable to insert models.
2 REPLIES 2
201 Views, 2 Replies
About 20 minutes ago I was suddenly unable to insert models into an assembly I'm working on.  I've tried repeatly but all I get is "There was an error getting files.  Please try again."  Up until that point everything was working fine.  I've rebooted, closed and reopened the program several times.  None of my normal "fixes" work this time.  Is there some problem on Autodesk's end?
2 REPLIES 2
Waited for over an hour and a half.  Still not working.  Software glitch or ???????
joel.palioca
Hi Mopar1952,
Are you still seeing this issue today?
Cheers,
[Joel Palioca]
[Software QA Engineer]
Joel(dot)Palioca(at)autodesk(dot)com
Autodesk, Inc.
