Examine the last Fillet feature in the timeline.
I had to select each individual edge even though tangent chain was active.
You can try it on the other side.
Solved by jakefowler. Go to Solution.
Oh, this isn't good.
If you try to edit the existing Fillet feature the edges that have already been selected are lost (I simply wanted to select the edges on the other side of the part).
Some good news: our recent bug-fixing in the development build appears to have resolved these ones:
http://www.screencast.com/t/ZhMAP6jt1Tn
(the edit manipulator looks a bit off though... we'll look into that).
These fixes should be in the next update!
Jake
Jake Fowler
Principal Experience Designer
Fusion 360
