I'm converting a T Spline and after a successful conversion, the original T Spline is deleted.
I have another body which I hide and certainly do not select - and it converts that as a T Spline as well AND deletes the original.
I've attached the file. thanks,
Solved by herzinj. Go to Solution.
Hey dcgall
I was just going through some of the "solved" posts and came across this one. I didn't really see a solution to it, but thought maybe it was solved offline or you solved it on your own. If you are still having problems with this, please let me know.
James
