Unable to snap to sweep path sketch point when defining sweep profile sketch and repositioning sweep path fails to reconstruct sweep.
Solved by peterschlem. Go to Solution.
Solved by jeff_strater. Go to Solution.
Error: The start direction of a path segment is antiparallel to the end direction of the previous path segment.
Keep getting this error any idea?
My friend with an odler version on Her Mac doesn't get it.
I have the
2.0.7830
Active Plan: Fusion 360, Personal
Vesrion and It keeps giving me that error
Tried to:
re-install
with clean registry
otherwise I am following a Fusion360 tutorial on-line and it just won't work
Thank you
@Anonymous wrote:Version and It keeps giving me that error
File>Export and then Attach your *.f3d file here.
Cite the url for the tutorial that you are attempting. (Just like in school.)
