how can you make a sweep along a path using multiple profiles?
https://drive.google.com/file/d/0Byzv_NlyKp_2c0Q2WmtjWG0wdUU/view?usp=sharing
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Hi Claas,
You can select multiple profiles to sweep as long as they are on the same plane.
To answer the second question in your video, it looks like you've created the plane using a "Plane On Path" type, which will always be normal to the path. When you edit the path, the plane is updating to remain normal. You can use another plane creation type (perhaps Offset Plane) to avoid the relationship to the path.
Hope this helps,
Charles
Claas Kuhnen
I misinterpreted you request. What I was suggesting is that you can select multiple profiles to sweep together in a single operation (example: sweeping multiple circles will produce multiple cylinders), but you cannot select multiple profiles at varying points along a path to perform any type of a swept blend. The Loft tool will allow you to select multiple sections, and a connecting rail.
To prevent the plane from updating with the curve, it can't be parametrically dependent upon the curve. A workaround I would suggest is:
1) Create your path
2) Create another sketch on the same plane as your path and project the endpoint of your path into the new sketch.
3) From that point, create a construction curve that is normal to your desired plane angle
4) Create a Plane On Path by selecting the construction curve, not the actual path
See the attached image. This will allow you to control the orientation of the profile plane separately from the path.
Hope this helps,
Charles
