Active Contributor
LeonMF
STL Export resolution
175 Views, 3 Replies
12-13-2013 09:05 AM
I've searched around the forum for something about this.  I found something about orienting parts for export but nothing around what I need.
Basically, round objects have a lot of segments and I can't find an option to increase resolution.  Is there any option to do this or an external tool that would allow me to increase the polygon count for more round circles?
Leon
Please use plain text.
Product Support
innovatenate
Re: STL Export resolution
12-13-2013 03:50 PM in reply to: LeonMF
Hey Leon!
Are you exporting from the workspace or from the Dashboard. If you right click on a Body in the Browser in a Workspace, there is a "Save As STL" command.
You can then choose a refinement or modify options for the STL file in the "Save As STL" dialogue box. Note: that you can preview the Mesh to see how the options may affect the resulting file.
Save As STL dialogue - refinement options - Low.pngSave As STL dialogue - refinement options - Low.png
Please let me know if this helps or if there are further questions/concerns.
Cheers,
Nathan Chandler
Active Contributor
LeonMF
12-16-2013 06:51 AM in reply to: LeonMF
I did not know about the ability to export a body.  Unfortunately, unless I'm missing something, this doesn't meet my needs.
Perhaps I'm not designing things properly but I tend to make things out of components and fuse them together with fixed joints.  Is there a way to perform this task for an entire assembly?
Employee
deyop
12-16-2013 08:50 AM in reply to: LeonMF
You can select components for Save as STL as well.  Both will work.
