Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
spline tangent to surface constraint
5 REPLIES 5
cekuhnen
470 Views, 5 Replies
is there anyway to make a spline tangent to a surface in Fusion and not just snap with the endpoint to an edge of a surface?
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
5 REPLIES 5
jiang.peng
in reply to: cekuhnen
Is the surface the "circle" face or lofted surface?
thanks
yqliu
I think one method is to Project Cut Edge of the body on the the spline sketch, and then apply tangent constraint onto the spine and the projected curve.
cekuhnen
in reply to: yqliu
That would be a doable workaround but it adds more complexity to the model.
Claas Kuhnen
yqliu
Agree. It adds complexity. And my proposal won't work if the spline is 3D, meaning a non-planar curve. Actually there might be some confusion about how to define " spline tangent to surface". From your perspective, what should the expected result be?
cekuhnen
in reply to: yqliu
Actually projecting 3D curves onto a surface works.
You can even also constraint a 3D curve to those projected curves - but only constraint coincident and tangent work and thus I do not have any more control in sculpting
the curve shape.
However for a 3D cuve I also would like to be able to snap the curve handle to the projected line - of course the constraints here only work because the projected curve is a line.
This is why there should be a g2 with editable weight constraint for the curve resulting more into a blend curve tool.
Claas Kuhnen
