Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Spiral along a path
8 REPLIES 8
Message 1 of 9
gabriele
6192 Views, 8 Replies
Spiral along a path
is it possible to create a spiral along a path?
I want to model a spiral cable.
regards
8 REPLIES 8
Message 2 of 9
sachlene.singh
in reply to: gabriele
Gabriele,
Depending of the profile of the spiral, something like this might help.
http://forums.autodesk.com/t5/sketching-sculpting-modeling-and/helical-sweep/td-p/5186239
-Sachlene
-Sachlene
Message 3 of 9
deyop
in reply to: sachlene.singh
Depending on what you have in mind you may be interested in this blog post.
http://forums.autodesk.com/t5/design-differently/creating-bike-lugs-in-fusion-360/ba-p/5129476
Message 4 of 9
deyop
in reply to: deyop
It also dawned on me that the Sculpt Pipe command would be a good way to create a spiral cable.  Define a curve and then use the Pipe command to determine how you want the twist to be generated around the curve.  You can get a lot of control with Pipe by adding and modify additional sections.  This link below is a good primer on using the Pipe command.
Create a T-Spline Pipe
Once the cable is created there are a lot of options for modifying the shape like this.
Message 5 of 9
gabriele
I mean this helix.
I modeled it in Rhinoceros
Message 6 of 9
deyop
I'm familiar with the Rhino command you showed.  I am not aware of a method to achieve it in Fusion.  It seems like a natural extention of our Helix command.  You may want to make a suggestion on the Idea Station.  I didn't see any previous requests for this.  I will check with development to see if there is an underlying capability we could expose.
Message 7 of 9
innovatenate
There is a Script where you can import a CSV file to create a 3D spline. If you have a set of parametric equations that defines the path, you can utilize an excel spreadsheet and the script to create  a 3D spline in Fusion 360.
Check out the below screencast for creating a spiral in a spiral, a slinky!
You'll find the necessary excel spreadsheet and CSV file for this attached to this thread.
Here's the website I used to get the equations:
http://math.stackexchange.com/questions/945033/helix-around-helix-parametric-equation
Hope this helps!
Nathan Chandler
Principal Specialist
Message 8 of 9
gabriele
in reply to: innovatenate
thank you very much!
with mathematics I'm not so good but now I'm understandig how powerful Fusion360 is.
I don't know if your script works with spline paths.
In Rhino this operation is not full parametric.
I would like to define the path, then extrude the spiral on it. Finally create the tube section.
All these things should be parametric. I can adapth the spline path, change the spiral diameter, it can starts large and ends thin, or also I would distribute the spires at head and tail.
regards
Message 9 of 9
innovatenate
The script will not allow you to input a sketched spline to follow. You would need to know the parametric equation for X, Y, and Z coordinates to create a spreadsheet.
It sounds like the tool you are looking for is not available. I hope you will submit a request for this command in the Fusion 360 IdeaStation. This is the best way to get features implemented in Fusion 360.
Best Regards,
Nathan Chandler
