Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Small problem using Parameters.
2 REPLIES 2
HughesTooling
244 Views, 2 Replies
I was experimenting with shelling a part and used the shell parameter (d14) to create a fillet so the fillet would match the wall thickness.
Clipboard01.pngThe problem is if you edit the shell it creates a new parameter so the fillet doesn't update.
Clipboard02.pngThe workaround would be to create a user parameter "Wall Thickness" and edit that but it seem odd that editing the shell directly creates a new parameter.
Mark.
Mark Hughes
Owner, Hughes Tooling
2 REPLIES 2
yes, that is definitely a bug.  I will file it, and we will get a fix in place, hopefully for the next update.
Until then, yes, the workaround you describe is the best way to do this.
Thanks for helping us find this one!
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
jeff_strater
in reply to: jeff_strater
Filed as FUS-15798
Jeff Strater
