I was experimenting with shelling a part and used the shell parameter (d14) to create a fillet so the fillet would match the wall thickness.
The problem is if you edit the shell it creates a new parameter so the fillet doesn't update.
The workaround would be to create a user parameter "Wall Thickness" and edit that but it seem odd that editing the shell directly creates a new parameter.
Mark.
Mark Hughes
Owner, Hughes Tooling
Solved by jeff_strater. Go to Solution.
yes, that is definitely a bug. I will file it, and we will get a fix in place, hopefully for the next update.
Until then, yes, the workaround you describe is the best way to do this.
Thanks for helping us find this one!
Jeff Strater (Fusion development)
