Sketch - making two ends meet (but how?)
5 REPLIES 5
lure23
620 Views, 5 Replies
Trying to make the end of a line, and the middle of a circle to meet.
Video: Does not get easier than this
What I'm trying:
- just make them snap (move one dot on top of another). Nope.
- select both dots, enable 'constraints' mode and pick 'coincident' constraint
Selecting the 'constraints' mode clears the line end selection, and doesn't allow it to be reselected. Why?
If I first creat the circles and then draw a line between them, I'm pretty sure the points get fixed. But I want to learn *all* the workflows. This should be easy, obvious and a no-brainer. It's remarkable that most problems I face with Fusion 360 are in this category (i.e. no real problems, but of the user interface).
Asko Kauppi
IT guy into Cleantech.
5 REPLIES 5
Macro.Liu_Autodesk
in reply to: lure23
Thanks for reaching out.
I tried the same thing in the latest version (1.8.604) and could successfully snap one end point to another by either of two ways below:
1. Drag one end and move to the second end, and when they touch each other, there'll be a 'GREEN' circle. Release the mouse will snap the two ends together. Or,
2. Select both ends and invoke Constraints (Coincident).
You can refer to the attached video for details. Please feel free to let us know if you have any question.
Thanks Again!
Macro Liu
Fusion 360 QA
lure23
in reply to: Macro.Liu_Autodesk
A very good video, thanks.
I am now able to do it exactly as you show. Maybe at the time I had the problem I was (unknowingly) working with two separate (overlapping) sketches. The current UI makes it a bit too easy to do this (i.e. create a line in another sketch instead of the current one).
I noticed that had happened only later, and copy-pasted the added elements back to the right sketch. I don't actually want Fusion 360 to *ever* create sketches implicitly (but cannot turn that off).
As a side note: SWF video files are not automatically recognized by Finder on OS X. The trick is to drag them to Safari.
Asko Kauppi
Macro.Liu_Autodesk
in reply to: lure23
You got it! Glad to hear thatSmiley Happy.
About SWF video, I did exactly the same thing as you mentioned on OS X. 🙂
BTW, would you please mark it as "Accept as Solution" so that others can benefit from this post.
Have a nice day!
Macro Liu
Fusion 360 QA
Interesting problem and reply. I cannot get this to work. I have tried for months and "coincident" does not behave as expected. It seems impossible to make two sketch entities snap together. Why?
jjurban55
Hi Jason, the most straight forward way to help would be to share a model that's giving you trouble with coincident constraint and let others offer suggestions.
Jesse
