big_red_frog
Sketch geometry is over constrained
309 Views, 19 Replies
03-23-2014 02:26 PM
Here is a new failure mode I haven't come across before, and stopped my project in its tracks.
Drawing as simple sketch getting ready to extrude into 3d.
Adding just a new 2 point rectangle.
Entering 10 and 2 mm's as the constraints, everything looks good.
Then I press enter a couple of times to complete, and instead of a rectangle I get an error message as per
Maybe I am missing the obvious, but shorly there should not be a problem with adding a rectangle...
Please use plain text.
big_red_frog
Re: Sketch geometry is over constrained
03-23-2014 02:35 PM in reply to: big_red_frog
Note that using a mouse click rather than return to commit the new rectangle worked fine, so at least I am working on.
Employee
NicolasXu
03-23-2014 07:21 PM in reply to: big_red_frog
Hi big_red_frog,
Thanks for reporting this issue.
It’s a problem that the development is looking into. And glad to know you have found a workaround. Hope we can improve this in future updates.
Recently, another user reports the similar case and you may want to check it for more information:
http://forums.autodesk.com/t5/Get-Help-with-Fusion-360/Fusion-360-update-bugs/td-p/4876674
Please keep the feedback coming!
Best Regards,
Nicolas Xu
Sr. SQA Eng.
Fusion 360 Quality Assurance Team
Employee
Cathy.Wang_Autodesk
03-23-2014 07:30 PM in reply to: big_red_frog
Thanks your post and detailed information!
The issue is reproducible. I checked it with Nicolas. Developer is working on the issue now. Sorry for inconvenience.
It's good to know you have workaround to continue your design.
Cathy Wang
Software QA Engineer
vspd1
03-24-2014 09:14 AM in reply to: Cathy.Wang_Autodesk
I have been fighting this issue as well. Driving me nuts.
Helmi74
03-25-2014 12:17 AM in reply to: vspd1
I had the same issue several times but didn't note that clicking the mouse could solve it. Will try it the next time it happens. Was driving me nuts already.
Frank (@helmi / Twitter)
Estimated 1974. Internet addicted since 1994. Resident of Bavaria.
Active Contributor
rekom23
06-01-2014 11:20 AM in reply to: Helmi74
Is it solved ? I'm using a mac version and i have the same problem. Clicking with the mouse doesn't solve anything for me. Am i doing it wrong ?
Helmi74
06-01-2014 11:24 AM in reply to: rekom23
no, it is just not solved.
Active Contributor
rekom23
06-01-2014 11:27 AM in reply to: rekom23
Hum after many others tries, it finally worked when i clicked with the mouse, but i can't find the correct process yet. Sometime i click left button and it doesn't work, sometimes it works... :robotlol:
Helmi74
06-01-2014 11:28 AM in reply to: rekom23
it should always work with the mouse button (at least it did for me so far) but the problem persists while pressing the enter key after entering some values.
