Sketch end points not staying attached.
Tried to embed video per forum instructions but keep getting an error.
https://screencast.autodesk.com/main/details/2de911da-8fb7-4a16-b9e7-5a733f4b5ac5
Solved by joel.palioca. Go to Solution.
Thank you for posting this. I am able to reproduce this issue on our end, looks like something is getting lost after the constraint and dimension are placed on the sketch. I will send this over to our dev team to work on a fix.
If you need a work around you can delete the horizontal contraint that you placed and instead create a dimension on the arc. This should help lock down the sketch for you.
Cheers,
