Ok, Fusion 360 parametric-sketch is very good ... but let me see how far it goes: Can I apply a controller for parameters ?
Example: I have a parametric manekin and I can change ( manually ) a parameter, one single unit at a time, to understand the manekin behavior. Kind of manual kinematics. Instead to change manually the value of a parameter, the question is: Can I have a controller associated with a parameter and specify for example, start/end values, incremental value and PLAY it ?
Fusion will calculate the new values, positions, display it, increment the parameter and repeat.
I see the "Modify/Change Parameters" panel as the ideal place for those controllers.
Solved by NicolasXu. Go to Solution.
I think it’s a great idea. I can image it would be useful in the concept demonstration phase. However, as you are probably aware, there isn’t such controller yet. We have Motion Study for kinematic motion analysis, but it’s based on joints, instead of parameters.
It would be great if you can submit this request to our IdeaStation – this site is the best way to get ideas and suggestions to us, and to influence the future of Fusion 360. Our product managers are constantly monitoring the Ideastation and capture this feedback for future Fusion 360 updates.
http://forums.autodesk.com/t5/Fusion-360-IdeaStation-Request-a/idb-p/125
Best Regards,
