Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
SERIOUS tspline bug - if you delete and undo an edge, you can't reselect it
3 REPLIES 3
lukepighetti
294 Views, 3 Replies
So I ran into this bug, and the most distressing thing is it seems to persist across all subsequent versions of a file.
If you open Edit Form, select an edge, delete it, hit Undo, and then try to select it again, you cannot!
https://screencast.autodesk.com/main/details/44370502-9c5b-4564-8e06-987d21336727
3 REPLIES 3
deyop
in reply to: lukepighetti
Yep, that's a stinkin bug.  I reported is as FUS-16310.  Hopefully easy to fix.  I gave it a high priority.
deyop
in reply to: deyop
Good news.  Fixed in the next release.
lukepighetti
in reply to: deyop
Thanks deyop, quick turnaround. 🙂
