So I ran into this bug, and the most distressing thing is it seems to persist across all subsequent versions of a file.
If you open Edit Form, select an edge, delete it, hit Undo, and then try to select it again, you cannot!
https://screencast.autodesk.com/main/details/44370502-9c5b-4564-8e06-987d21336727
Solved by deyop. Go to Solution.
Yep, that's a stinkin bug. I reported is as FUS-16310. Hopefully easy to fix. I gave it a high priority.
