Greetings,
I tried using the web interface to drag and drop an SAT file to get started. It errored by saying the limit was 50 MB.
If I install the client from the website, will it too have this file size limitation?
Thank you,
-Thom K.
Solved by schneik-adsk. Go to Solution.
Adding content via the web client is not a good idea today. The web client is tailored to create viewables not first class Fusion 360 CAD data. We will be adding that ability very soon. Uploading thru Fusion 360 will create Fusion data and will not have the 50mb size limit. We currently only start to see problems with 1GB or larger files. That too is an area we are improving.
