I can't upload a dwg file created in Rhino and exported as Autocad 2004. The upload process fail.
regards
Solved by joel.palioca. Go to Solution.
Would you be able to share the file so I can take a look? Also what kind of geometry are you trying to bring through from Rhino?
Cheers,
I was able to get the file to import into Fusion, but I had to update the DWG version to a more updated one. I ended up using the 2013 version and the import is successful. That being said I would be interested in understand what your intent is with this data once you get it in. Looking at the data inside of AutoCAD and comparing to what comes into Fusion there is obviously a number of items that Fusion cannot deal with because we don't have the capability at this moment. Also when I open up the data inside of AutoCAD I am getting a couple errors which may be the reason we are also seeing issues. Here are some of the images that were captured as well as the updated version of the .dwg.
Cheers,
Because I found very interesting the possibility to store 2d and 3d models into the Autodesk cloud, share and render them, I tried with a file that I received from client of mine.
Because I don't have Autocad I opened this file in Rhino for Mac and saved in dwg format.
I tried also with a simple 2d shape. I created it in Rhino and save it in dwg format, no lucky.
My goal is to prepare 2d drawings with Rhino and 3d models with Fusion, store in the A360 cloud and visualize them with iPads. I'm testing the possibilities.
regards
Okay understood, thank you for sharing that information with me. It is always good for us to learn what our customers are trying to do with our software 🙂
Not sure if you have played around with it at all, but inside of Fusion we also have the capability to create 2D drawings that are based on the 3D models you create inside of Fusion, it may be something to take a look at. We are still in the process of improving the capabilities inside of it, maybe it has or will have soon what you are looking for. The nice part is that they are associative, so that when you make a change in the 3D model it should update in the 2D drawing for you as well.
Cheers,
