After a few seconds, render mode fails and outputs garbage. MacBook Pro. The background is black in Fusion.
Always the same effect, independent of model or Fusion version (since beta)
Product looks great in A360 though...
Solved by Phil.E. Go to Solution.
This is a video issue, obviously. If you don't mind I would like a little more information to help us optimize Fusion for all video environments.
What are your video card specs?
Are you running two monitors?
Thanks!
Intel HD Graphics 3000:
Chipset Model:Intel HD Graphics 3000
Type:GPU
Bus:Built-In
VRAM (Total):384 MB
VRAM (Dynamic, Max):10
Vendor:Intel (0x8086)
Device ID:0x0126
Revision ID:0x0009
Displays:
Color LCD:
Display Type:LCD
Resolution:1280 x 800
Pixel Depth:32-Bit Color (ARGB8888)
Main Display:Yes
Mirror: Off
Online:Yes
Built-In:Yes
Unfortunately, the Intel HD 3000 graphics chip set is just not robust enough for rendering. Right now we are working towards graphics certification and it's looking like cards like this may not be supported. Typically for 3D graphics you would want 512 MB or greater GPU memory. The recommended card for Maya on Mac, for instance, is almost a full GB.
Things you can try:
Reduce the load on your graphics following these suggested settings:
Also, you could try reducing the window size of Fusion during rendering. Or consider getting a more modern and CAD capable graphics card.
Hope this helps!
