I'm having a heck of a time organizing and removing items from my dash board. In particular I have some items that are simply not selectable, so I can't delete them or open them.
How can I remove these nuisances?
Hi if you cannot delete or open certain files at the dashboard you might be able to delete/open your files by promoting older versions (if you had saved a few versions before). In the early days of Fusion 360 it was possible to create files with errors that the user could neither open nor delete them. First select "Action" from Dashboard, Activity or Data
Then select to open file details from the action menu. Find Versions and click that. (you might see an error message when doing that, please ignore that. It is a bug I believe). If you had saved a few previous versions just select one of the old ones and click the up arrow. The older version will be promoted and you might be able to delete/open them normally. I hope it helps. I used this method to delete files with errors that could neither be deleted nor opened. In the early days (first version of Fusion360 after beta) it was very easy to create those files with errors due to constant crashing of the computer or simply being just a new learner user.
Saddly, none of these worked. They don't allow the designs to be clicked on, and they don't show up when you click the 'designs' button.
There is nothing to promote, because they just don't seem to exist. I can't open them to edit them. They have no icon. They have nothing.
They can't be clicked on. Edited, selected, nothing. And there is nothign to promote. One is even a PDF for some reason.
Hi May I ask are you using a trial version, a paid version or a free license version? Usually if you access your file from DATA to your related folder, then navigate to the file in question, click the Down arrow for action you can still get to the Version part without opening the file. If all these failed please check your license situation. If you have a license then an Autodesk representative might be able to help you better.
Sorry that my suggestion could not help you.
I have a licensed verison
I've tried everything I know how. And your suggestions where helpful.
I've given up for the moment and am trying (and failing) to do a hirth element. 🙂
I'm using the Mac as well, and I just used the uninstaller. Hopefully that fixes at least the one part. I'm not running Yosimite if that's the next question. 🙂
The biggest issue right now is the hirth part. Not sure how to make trangular bodies that get smaller in the center (the sort of spin around a circle and lock into another piece.
Deashboard polution is an annoyance, but I can live with it for now. I'd love an checkbox to just delete things easiler.
Hi after uninstalling you still have to delete the files according to the instruction of this forum. The uninstaller does not delete the files in error. I do not think Yosimite is here yet.
for you triangler body, maybe you can try to use the create Form part, then form a triangle by sketching and using the extrude function from form editing. Then you thicken it by selecting no edge.
That will create two triangles one at the exact center of another.
The installer should remove these files. I have a huge issue with that since during the day I am an Apple Software Engineer. 🙂
I can make it with the circular pattern, but getting the thing to make into a circle is the thing.
That sloped triangle is somethign I'm having no end of issues with.
I'm going to move on for now. The project is an extension arm for my Ottie dashboard mounter for my car. So I can get it further out. The rest is simple caliper and replication work. But this is a pain. I may end up just using a small piece of silicone taped to the 3d printed peice and then it'll provid the friction.
Sadly no responses to my hirth thread.
