i can reproduce this problem within my document but unfortunately cannot reproduce it in a new document:
Whenever i copy & paste new a component (direct model mode) i cannot push/pull this new component. The arrow appears and i can drag the arrow but the face doesn't move. When hitting enter and retrying the same happens. After closing/saving the document and reopening it the push/pull seems to have happend to the source the component was copied from. From that point everything works fine.
I had this happening several times in my actual assembly but tried to reproduce it in a new one without success.
Anyone who wants my assembly shared for testing?
Yes, please share with me, I have sent an email address as a direct message, or you can export a design archive and send it to met at kevin (dot) schneider (at) autodesk.com.
We will take a look get you some suggestions.
Hi Helmi,
Please include me as well when you share your file(s). My email is sanjay (dot) jayabal (at) autodesk.com. As Kevin stated, we will have it looked at and get back to you.
Best regards,
Sanjay Jayabal (Autodesk)
Can you they this? In the dashboard click on the title of the design to share and in the popup pane click share - > Invite
Then enter the email address is sent
Any solution to this problem yet?
I'm experience the same thing.
I'm also having problem mirroring component, In the preview all looks fine but when i press apply the component gets mirrored and moved randomly.
If i reopen the file after i pushed/pulled on a paste new, or mirrored a component, everything works fine. I can push/pull the paste new file and the mirrored components are on the right place.
Hi Tom,
Can you send me the file? Please send to andrew.sears@autodesk.com
Andy
Frank,
I sent you an email to see if you are available for a screen share. Let me know if now is not a good time so we can schedule a better time to go over this issue.
I can update the post after.
Andy
i'm here - send your invitation and we can go straight ahead.
Thanks for meeting with me Frank and helping me reproduce the issue. The issue seems to come up with Copy/Paste New after you have performed mirror or patterns with the copied components.
We will look into this more and get back to you.
Andy
All,
This is simpler to reproduce. The problem starts when drag another component into another component to make an assembly. After this, when you use copy/paste new the copied component and new component are not displaying the correct length after using press/pull. This is also giving wrong values when measuring.
Until we can get this fixed I have a workaround. Closing the model and opening it again will show the correct edits.
Andy
