I want to move a 2D sketch from the plane it was created on to a parallel plane 1mm away. When I select Redefine command and click on the new plane, the sketch orientation changes when its moved to the new plane. I see no option for limiting/controlling this behaviour.
https://screencast.autodesk.com/Embed/Timeline/30163461-4beb-42bb-9ca2-be91f17d6179
Solved by jeff_strater. Go to Solution.
Dear Sir,
for copying a asketch to a parallel plane u can and then go to the parallel plane on which u
steps:-
1) copy the sketch from the existing plane.
2) go to the parallel plane then paste the sketch
