I have the profile of the screw. I am trying to create several offset planes. Each one is going to have a copy of the profile with a rotational increment. In theory, the loft command should join all the partial profiles into the final screw. For some reason, it is not working. Any suggestion? I am going nuts after 6 hours of trying different approaches.
Javier,
You will need to create a 3D spline that connects all the profiles and use it as a rail for the loft. @innovatenate 's video in this thread has been very helpful to me in the past: http://forums.autodesk.com/t5/sketching-sculpting-modeling-and/helical-sweep/td-p/5186239
I hope this helps,
-Sachlene
