I am trying to pattern an object or sketch on the flat face of a cylinder. I would like to ultimately pattern the rut of a gear 63 times around the cylinder, but for some reason when I try and pattern it 63 times, autodesk instead patterns it 62 times. If I type 63 into the box window there is no change, but the quantity on the tool bar still says 62. If I then type 63 into the tool bar, it changes the quantity in the window box to 62. Pushing the up arrow in the box window does not do anything. I tried doing this with only a vertical line at 63* but it still will not pattern it 63 times. Trying to pattern them around 126 times also fails. However, all other numbers seem to pattern the correct number of times, including 61, 62, 63, 64 etc and 124, 125, etc.
I've included some screenshots.
Thank you! I am pretty new to autodesk, so I hope I am using the program correctly.
Can you attach the *.f3d file here?
(I am pretty sure I would pattern Feature rathern than Sketch for that design.)
I exported the file as .f3d but when I try to upload it here I get an error saying "the contents of the attachment doesn't match its file type"? Am I doing something wrong?
No - you are not doing anything wrong - this site is messed up.
Right click on the filename and select Send to Compressed (zipped) Folder. Attach the resulting *.zip file.
Hi
Just tried to replicate that issue and it worked fine,
And do try to push one of the box input value to 63 and if other if the other is 62 put that value to 63, there may be some kind delay.
I’ve put a file where i think there are 63 extrude cut patterned
Best yours truly
Rishi Vadher
Personal Page
Facebook | Twitter | LinkedIn
Thanks! Here are the files. The first is the cylinder with a simple line and the second is the one with a the gear rut.
rishivadher,
Thank you for making that and reply to my post. If you count the number of teeth or ruts in your gear, I'm pretty sure there are only 62. You can tell it has an even # because there is a rut 180 degrees from the rut at zero, while with an odd number there would be a tooth there instead.
