Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Problem importing Solidworks assembly
3 REPLIES 3
despolose
309 Views, 3 Replies
Hi, I am working with someone that uses Solidworks and it turns out that it generates a folder with the several subparts of an assembly. In the import panel in fusion I can only select the assembly file and then I get an error log telling it could not find the subparts, which are actually in the same folder.
Is there any workaround or this feature is not yet implemented?
3 REPLIES 3
innovatenate
in reply to: despolose
Are all of the SLDPRT, PRT, ASM, & SLDASM located in a single, flat directory with no sub-directories?
When using the "Import CAD Data from my local hard drive" command, is the "Import an assembly" radio box checked?
Can you share the Solidworks data with me? Feel free to e-mail to nathan (DOT) chandler (AT) autodesk (DOT) com.
Nathan Chandler
Principal Specialist
despolose
in reply to: innovatenate
Sorry, I am afraid that the problem is with the files themselves, not Fusion's mistake. Thank you anyway for your reply.
cekuhnen
I also had two SW assemblies and Fusion just created some garbage and empty files because there were errors.
I have the suspicion that the SW importer is not fully working.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
