Hi all!
I'm relatively new at this, and really want Fusion 360 to become my main CAD tool, but can't handle the incredibly slow update speed of mildly complex sketch changes.
I'm creating a top-down design of an integrated servo motor and transmission, and once the driving cross section sketch reaches 50 or so lines & dimensions, it takes 10-20 seconds to do every single alteration, including simple cosmetic changes like dragging a dimension for visibility.
Quite often the sketch will report an error after freezing for a few seconds, saying that it was unable to update because it was "overconstrained" (it's definitely not overconstrained). Trying the same change again a second later would sometimes resolve the error.
My suspicion is that the whole sketch is being rebuilt after every change, including cosmetic changes like dimension positions. Once it reaches a certain size it will start timing out after a change, and reporting that the sketch is overconstrained. I have experienced this in more than one sketch.
I have reinstalled Fusion 360 twice and upgraded my graphics card drivers without any changes in performance. My machine is an i7 quad core powered laptop with 8 GB ram and a fresh Windows 7 Pro install on an intel SSD. It's also got an AMD graphics card with 1GB dedicated G5 memory.
Large sketches work well in other CAD packages on this machine, which makes me wonder why Fusion 360 suffers so much...
Any tips on how to trouble shoot sketch performance?
Thanks!
Solved by cekuhnen. Go to Solution.
Just wanted to bump this issue a bit. I have a relatively complex design I am working on with a lot of history. Things went well for a while but now everytime I do anything in the sketch screen it takes 15-20 seconds to compute something. I have a half year old mac book pro so its not the underlying hardware and I don't experience this with my simpler projects so much. This one has gotten unbearably slow however. I have also seen 'overconstrained' errors that are obviously wrong and my suspicion is that its somehow a combination of your contraint solver and/or your history system. This is could get me to switch to solid works which is unfortunate because I love many things about the way this software is designed. Design changes that took me minutes in the past now take close to an hour because every line I draw is a 20 second spinning wheel...
Question - can I turn off history after having gotten far into my modeling? Is there a way to expire history older than X alternatively?
Cheers,
Dan
Hi Dan,
Please kindly notice turning off the history would lost the capability of parametric update. Also, there is another way to convert the selected feature and the features prior to it into DM (Direct Modeling) feature. (Partially convert contrast to entirely convert by turnning off the history)
In your case, does it happen to a simple sketch as well? It sounds some sketch objects or their relationship introduced the problem. Would it be possible to get a copy of the files in which you see the problem? We can look into it and investigate the root cause?
You can either Export the entire file as .F3d format or Share Public Link with me by enabling the download permission. Both commands are available under the File menu. My email address: lixiong.xu@autodesk.com
Sorry for the inconvenience.
