Hello
I have a design with a Pattern on path, changing the Count variable in the dialog box does change the occurences, however it seems when changing the Pattern Count variable in the Change Parameters window, the pattern does not update correctly, it is only when opening and OK (change nothing) the the Pattern operation (the changed count value is correctly displayed) in the timeline that the Pattern updates.
Am I overlooking something?
Many thanks and kindest regards,
LMD
Solved by zhanganchun. Go to Solution.
Hello LMD,
Thank you for reporting the issue. That one is a bug for Pattern along path. Will create a bug for Dev. As a workaround of changing the occurrence count, please edit that pattern from timeline instead of changing it from the ChangeParameter dialog.
