workere here
why not here
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
I cannot edit the first post but the image was wrong
Here are marked the tip better. While the side shell loft command totally ignored the cross section tangency to each other, the tip can be patched
with G2 and G1. If the main shell is done with a circle not half arc the G1 G2 tip patch fails and is only G0.
But you showed an interesting idea for solving the problem in this post:
http://forums.autodesk.com/t5/Help-and-Support/tangency-problem-with-loft-rail/td-p/5178329
However the loft tool should just work with the rails like in Rhino and not do this crazy thing it does in Fusion making
a rail positional and not keeping the arc tangency.
Here is the Fusion Video - the surface is useless.
https://drive.google.com/file/d/0Byzv_NlyKp_2ZW5Hc1EycUdGU1E/edit?usp=sharing
Here is the Rhino Video - thats a surface I can work with:
https://drive.google.com/file/d/0Byzv_NlyKp_2RnNHUFNtTTlKTlk/edit?usp=sharing
Claas Kuhnen
