and another show stopper bug in Fusion:
a part from a base feature always is hidden when leaving edit going back to the timeline
this is another bug which makes currently Fusion nearly unusable because of this. I had this happen today in this file quite a lot copy paste hide show explode join sometimes helps. this one is resisting!
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Still looking for the underlying cause, but I think I found a workaround that will fix the design. If you just edit that base body, then do some kind of dummy edit on this body (I did a press pull of this face by 2 mm, then back by -2mm):
then, after exiting Base Body mode, this body appears to be OK.
We will keep looking at the root problem. Thanks for reporting it!
Jeff
