tried using offset to create line after line on this but wouldnt let me do anymore than one.
its a tree stump made through a sketch and then pull. the offset was to be the age rings
Solved by innovatenate. Go to Solution.
There are some known limitations with offseting spline figures at this time. Would it be easier to create a custom appearance or apply a decal to the face? What is your intent by sketching out tree ring (if you don't mind me asking)? Is it for cosmetic reasons or do you plan to generate 3D geometry from it?
If you share share the design with this post, I will be happy to take a closer look at the design.
I made a quick screencast to show the decal and the custom appearance workflow.
It's a quick video, but I hope it helps. Let me know if you have any questions or concerns.
