Hi autodesk fusion 360 family, does anyone know how to create numbering bubbles for assemblies? objective is to create a bill of materials from an assembly.
thanks
Huber M
Solved by innovatenate. Go to Solution.
Huber,
The capability to create balloons and Bills of Material has not been introduces in Fusion yet. As a work around, you can use the leader command in the Drawings to add text to your 2D drawings.
To create a drawing from a design, open the design, click on the FIle menu and then choose 'New drawing from design'.
I hope this helps,
Welcome to the Fusion 360 community! Thank you for posting your question.
The closest function seems to be the leader text at the moment. You might add a leader text with the Item Number or Part Name listed as the text.Are you doing the Bill of Material or Part List in a separate spreadsheet?
The best thing to do is let the Product Management team know that you value this feature by submitting an Idea to the Fusion 360 IdeaStation.
http://forums.autodesk.com/t5/fusion-360-ideastation-request-a/idb-p/125/tab/most-recent
Let me know if you add the suggestion and I will Vote it up for you!
I hope this helps.
Thank you,
